Launcher Pro Problems
Sparro
24
I just installed Launcher Pro (Free Version) on my Atrix. My problem is that the second button from the left, the one after the phone button always launches the dialer. I changed it to contacts, gmail, text... you name it... it always launches the phone app?
Anybody know why this is happening or have a fix?
I'm having the same issues and having trouble assigning different actions to the buttons.
Thats weird I just changed mine to and from dialer and it worked perfectly each time.
Sent from my MB860 using Tapatalk
I found a fix on another forum and will post what worked for me.
Credit goes to Czarcat.
I have no idea why it would do that. But, you might try changing the shortcut to BLANK. That should wipe out anything it wants to do.
Then, you can just set the shortcut to whatever you'd like it to be. Be sure and change the icon as well.
I just dragged the icon I didn't want into the trash can. Then I added the shortcut I wanted to the home screen first, then dragged it to the launcher. I have changed several with this method and have no issues.
kiki2025
