Launcher Pro question. Help
tbizzy1985
63
3
OK so I've had LP+ for a while now and love it. When you hit the home key a screen will pop up and have you choose Launcher Pro or the stock launcher. So I just recently hit the choose as default and picked LP because I never really use the stock launcher. . . . . But now I can't figure out how to get back to my stock launcher. I feel like an idiot
And also as a follow up question, would taking off all of the widgets and what not I have on the stock launcher save any battery life? I'm not sure if those are running in the background or not while I'm using LP+
Menu - Settings - Applications - All Applications - Click on Launcher pro, then click on Clear Data. That should reset it so it pops up and asks you every time again.
Clearing widgets on unused launcher will do nothing. Deleting unused launcher will help.
Reactions: tbizzy1985
Acutally it does......there was a thread awhile back that showed an decrese in to android aoperating usage if ur cleard all ur sense wigets if u were using a different launcher
Actually that worked all the way up until the last part. . . I hit clear defaults not clear data. . . I didnt want to lose everything I have set in LP+ but still thanks
Alexa_daniel
