[Leak] 2.11.605.5 -many fixes from GB OTA
The_Engine
Super Genius
Apr 19, 2010
327
13
[Exclusive] Gingerbread Build 2.11.605.5 For The HTC Thunderbolt, Fixes Several Issues From Official Gingerbread OTA
Source Android Police:
Thunderbolt owners have been waiting a long while to get Gingerbread -- too long, considering this phone was once Verizon's flagship. We've seen several leaked builds come around, all of which experienced a variety of problems. The most recent leak seemed to be the most stable so far, but it was still chock-full of annoying little bugs.
Fortunately, we've gotten a hold of a newer build (2.11.605.5) that fixes a lot of the issues from the 605.3 build, so HTC is clearly heading in the right direction.
Here's a summed up version of what's new in this build:
HTC Logger removed
Voicemail notification fixed
Front facing camera/Gtalk fixed
MMS/SMS Fixes
Weather syncing fixes
...and more
Hit the link for detailed install instructions and all that...
Sound good? I thought it might. Head below for download and installation instructions.
VZW only about a hundred more updates away from catching up to bamf forever.
i'm running BamfForever 1.7 & i still have a sideways ffc on g-talk/hangout..so..hopefully BAMF will release an update (incorporating this software) to fix it. as for everything else--they're ahead of the game.
love BAMF, but hate that bug (across any ROM i've installed) unless i missed an update along the way :)
edit: i am corrected! 1.8 fixed the inverted FFC! awesome
Like they did about three days ago? 1.8 fixes it. It is not posted here at android central.
Head on over to rootz wiki.
Sent from my Bolt via Tapatalk.
i think i was checking the forums & finding the 1.0.8 thread (@bamfnet) while you were typing.
found it/downloading/flashing it tonight to test it out. thanks though
Rooted with bamf 1.0.7 do I need to try and install this new 2.11.605.5 or just wait for bamf to come out with a new rom?
Bamf is awesome but doesn't fix all problems. I have constant data drops with any GB based ROM I use...must be a flaw of GB in general. Data is fine if I run froyo.
I hope this latest GB release will fix that. If so ill wait for Bamf to release a build based on this.
Sent from my Thunderbolt using Tapatalk
2.11.605.5 - md5 mismatch
OK has anyone noticed again that the listed MD5 doesn't match the file? The last build released did not match either..
I've always used the Multiupload links to download these RUU's and the MD5 has always matched. :)
Has anyone heard any new info on whether this may be the same as the official OTA? I'm thinking this may be it as it's been almost a month now since the original GB release. Wouldn't think they'd wait more than a month to get the fixed GB out or that there is time before the month's end for another build to be in the works. I'm really tempted to pull the trigger on this latest leak!
There is actually a bamf forever 1.0.9 its a small patch about 8mb. You have to have 1.0.8 flashed already though for the patch to work.
Sent from my ADR6400L using Tapatalk
Weather syncing - hmm. Maybe my weather apps will correctly locate me when I am at home and using a VZ Network Extender.
pvk
