Leather Side Case for Extended Battery?
pppilot
Active member
Nov 17, 2010
33
Has anyone found a leather side case (worn on the belt) that will fit the Tbolt with extended battery and a gel case? I had been using a leather side case made for the Driod X with my Tbolt with the standard battery and gel case. I found that it will also fit the Bolt with the extended battery without the gel case, although just barely. But the flap will not close when the gel case is used. I like using the phone with the gel case and also like carrying it in a leather side case on my belt. I've searched the forums and numerous vendor sights with no luck.
Has anyone seen or used a leather side case that will fit the bill?
Thanks for any help you may be able to offer.
visionarysearchist
