LED Application
comptech520
71
Hi,
I'm using NO LED but it does not show notifications for my corporate email.
It does not show an option for it.
Are there any other apps for this that will show some sort of notification?
I'm not sure if corp email is a different server type issue, but it was tricky for me to check off the right boxes to get my Yahoo email working too.
can you receive corp email now?
I posted the steps I did in this thread's last post.
http://forum.androidcentral.com/showthread.php?p=998877#post998877
Recheck your settings.
Also under "toggle notifications" you need to hold down "Monitored Apps" and it loads another page of listed apps on your Charge. You need to check off some in there too. I missed this step the first time I tried it because there was no check mark to the right of it and I did not know to press down "monitored apps.
Does you Gmail give you notifications?
There is a link to the developers site in the link above and you could also post a question there too if you can't get the setting checked off correctly in Noled.
OK, thought I might have found the solution for no LED message light, but don't want to use the screen as the LED.
Has anyone found an App that will use the camera LED light as a notification LED?
Md ripon sorkar
