Led cover for note 9
  • Start date Start date
A
Android Central Question
my note 9 has no accessories option n setting under name advance features so how to conect and how LED case will work...thanks
Well if you purchase a Samsung LED Cover, as soon as you'll put your phone inside, the option will show on your phone.
The LED case works with the NFC of the phone : for both communication and power supply. On the back of the LED cover is the receiver and there is a ribbon that goes on the front of the cover to the LED display. That's why it is recommended to not fold the cover all the way to the back (otherwise with time the ribbon will break and the leds will stop working)
After your case is installed the app called LED Icon Editor will allow additional set ups. I just like the way it turns on the phone when the case is opened and then shuts it off. I do not use fingerprint or anything else. StephaneM60 above explained it very well. Enjoy........BTW I have the blue and black one.
I have this case and I had the same one on the note 8 however for some reason this one the cover doesn't close tight, anyone else have this issue? Even set on the desk the it's opened alittle.
Ya mine is the same way and I also have the white dome protector on. Usually when I dont care about notifications and just wearing my earbud I just flip it to rest on the front and or stick in my back pocket. Love the performance and feel of this case and its my daily case.
Glad it's not just mine, I've no idea what they changed from last year but the one I had for the Note 8 never done it.
Mine now close completely (I put the phone in my pant front pocket), on the contrary the cover wont stay open on mine :D I never had a LED cover before (but a ClearView Cover) and it's the material of this LED cover that is thicker (maybe they did that to prevent the case from failing after being opened / closed mutliple times)
I now also own the official leather wallet cover, and I find it alot better. It doesn't cover the edges of the phone but it's far more practical for changing SD cards etc .
gmcbride
