LED keeps on shining
Ecir Hana
5
I received a message and since then the LED keeps on shining in very dark blue. Even restarting the phone doesn't help.
Please, how to make the LED to turn off itself? Did anyone experience something similar?
Running 4.0.2
Running 4.0.2
Have you installed any LED apps like "light flow"? Is there a message notification? Have you opened the message?
As you can disable the LED that would of course be one way. It should generally (bugs...) only be on when screen is off.
Reactions: Ecir Hana
No apps.
The message has an attachment, probably it was MMS from iPhone. There was this "Download" button, which triggered downloading of the message, which never finished.
However, all of sudden the LED turned off, I think it happened after I plugged in the battery charger.
Nam Ng19
