led light suddenly blue?!?
cheeta186
344
3
ok i was opening a message and the blinking green light suddenly turned solid blue, y would this happen? nothing i did would turn it off, i finally turned off my phone and turned it back on. it is now gone, y would this happen?
does this when hi yahoo gets a message on my phone. Some apps you can set a notification, and their color
where would i go to see the different colors of led's that i can see, and is there a way to change the color?
Facebook app also does blue notifications when you get an inbox msg in facebook. You can also see the different LED colors if you use the Missed Call app in the market. The app lets you assign different LED colors to some of the different services such as calendars and sms.
There is a malfunction with the software, i called verizon. I had the same sitation.
I had the same situation, there is a malfunction in the programming and or software. I called verizon, they confirmed this.
