LED Light?
HDCPRD
3
I use the handcent SMS app for texting and there is an option to change the LED light but for it doesn't change it at all, still the green flashing light. I been looking around the phone settings but with no luck. Is there is a way to change the LED light color?
The reason I ask is because I had a friend with a blackberry and has an app to change the color of the LED light so I thought my HTC sprint Hero will have an option as well. Thanks for reading
htc decided to only put a dual color led light in the hero(green and red) so no matter what the app tells you you still only have those two choices
Im using handcent and have mine set to red but the green is the only color that works for me.
I had a BB too and loved the BerryBuzz app they had for it, you could change the color of the LED to even a multi-color flash so will miss that but am happy the Hero even has what it has, the Moment didn't and that was one reason I switched to the Hero.
so your saying that no matter what, those 2 colors are all we will ever have on the Hero?
When I first go my BB Curve, it would only show one color also until BerryBuzz came out for it, it wasn't available at first, so just asking to clarify. I know they are 2 separate OS's but was hoping with upgrades we would have mre choices in LED preferences. It would be nice to have mutiple choices for each contact, messages and email as was in BerryBuzz. Could even set up separate vibrating patterns.....pretty cool little app. I might add.
doesn't it have orange too? i think when i charge it its more orange idk
The fact that it doesn't change to Orange or red if you try to set handset to do so makes me think its just ported differently. If you know, however, through ifixit or something that its just a 2-3 color LED, then that is a feature we'll never use, but just about every other HTC android phone does. Confirmed it works on G1 and mytouch 3g. N1 lights up track balls in multiple colors essentially doing the same. Thing.
zolepso1
