LED Notification Light
Cnote187
Active member
Dec 22, 2009
30
Is there a way this can be changed? The dim green blinking light is not enough for me. can you change the color or anything? has anyone figured a way to do this?
You serious no way? no program that does it?
i'm guessing its not the typical rgb led lights that can be used to make different like blackberrys. prob just 2 led, maybe u can mix green and orange to make something?
download handcent sms...you can change LED notification lights within that app. for sms and mms messages. its also a better messaging app than the standard...give it a shot,theres a massive amount of customization:)
Another thing that would be nice is to disable the light when charging...I don't get the blinking green light if i have a new message when it's plugged in - the solid orange/green indicating charge status overrides the notification light
I think it will be changed in software updates or a 3rd party app.
I remember when I got my POS Storm and after a software update on the OS it got way brighter.
I wish I could agree, but I ended up uninstalling BerryBuzz because it just got annoying with all the different notifications. I ended up finding out my personal taste ranged to where I just wanted to know when I was getting email not everything else lol. More color options would be awesome though!
Lol, I understand. For me BBuzz is a gem for determining who is contacting me and what form of communication they're using. I also like the cool factor ( call LED notification=red & blue police strobe lights!) :cool:
I agree having color options would be great..:)
Yeah, but it had disco! How can you not love disco?!
I ended up having to send my BB for repair and wasn't ever able to authorize the new one to use BerryBuzz (suck it BellShare). In the end, I found it much more peaceful not to have my pocket vibrating and lighting up every color imaginable in 2 minute intervals with some kind of notification.
Yeah it was a bit over kill for my tastes. And yes, the police strobe is what I used for phone calls, it was awesome. I used the blue and white alternating for twitter and a mix of colors for sms etc. It was cool at first but got annoying after awhile. But like most phone things it's all down to personal taste. I like the fact that my android shows hardly nothing and only gives me notifications in the bar up top!
Lol, I'm using same colors for UberTwitter. But, I think it'll be refreshing not to be bombarded with notification messages.
I would just like more options. I rely heavily on the flashes and color differences, I hope they give us more choices with updates in the future
soraplzzzzz
