LED Notification
cajunbeast
127
Anyone know why my led Notification doesn't work? I have them all turned on. I don't want to download some third party pop up sms or anything. I'm not getting ANY notifications with my LED. It only lights up when I'm charging. Anything helps. Much appreciated.
Hi mate. Put this code *#*#3424#*#* into you phone keypad and it will run a built in diagnostic test on your device. If your led is not working due to a hardware issue, it may be covered under your warrenty.
Let me know if this helps at all.
Just did and all LED components are working. It just doesn't turn in when I get notifications. :-\
Seems like an obvious question but the option to use led for the specific notifications is switched on in settings I guess?uploadfromtaptalk1397893389257.jpguploadfromtaptalk1397893406277.jpg
Sent from my HTC One using Tapatalk
Sorry buddy, the only other thing I can suggest is a call to HTC or a visit to the shop you bought it from. Must be a hardware issue.
RichardDixon
