Led view cover and fast wireless charging
ApolionOs
Hi all. I have a s7 edge with LED view cover and samsung fast wireless charging stand and I noticed when using the stand with the cover on the phone gets heated up. It's possible that the ventilator on the stand doesn't get through the case to cool off the phone as it does when using without case even though it samsung says it's possible to use the charging stand with the LED cover. So my question is does anyone have experience with this and do you think it's safe to use the stand with the LED cover?
The fans on the back are not meant to cool off the phone, but the charging pad itself. If you put your hand behind it when the phone is on it, the air is blowing out, so I assume theres some sort of heatsink in there and this is drawing the heat off and expelling it.
theantithesis
