- Apr 25, 2015
- 9
- 0
- 0
So I have had an LG G Flex 2 for quiet some time now. (Not under any warranty)
It was working fine until one month back it randomly began to restart on its own.
The problem got frequent gradually and the battery percentage would change after the restart so I got to know that its a battery issue so I got it changed from a local repair shop and it worked fine until two days later, it simply shut down on 52% battery(not restarted)
It won't turn on until I plugged in the charger and it booted up at 52%(Note: battery percentage did not change).
It works completely fine but sometimes at 52%(generally between 50-60%) it randomly shuts down and I have to plug the charger back in to boot it up(once in about 2 days), it works fine after that until battery is completely exhausted.
Now can anyone explain that whether the new battery is bad too or is this a Power IC issue? What could be the fix here?
