LG G Watch Battery Problem
Jeffrey Porter
3
I recently bought a lg g watch and getting on average 3 hours which I hate that is not even enough for work. I have read online and was expecting a day and a half which would be great. I have just been charging it 8 times a day so i can just wear it so somebody please help.
Wild question: How is your cell reception (not data, not wifi) where you are getting bad battery life?
Most days I end with 80-85%. Do you have you screen set to "always on"? If so that could be a part of the problem.
You should be able to use always on with the g watch...this isn't moto 360 we're talking about. I would try factory resetting the watch and don't install any wear apps for the first few days, run completely stock. If you are still getting 3 hours, your watch is defective and you should return it.
pauldop1982
