LG G2: battery drain after update.
Re: battery drain after update.
battery seems to have gotten ever better after update for me... and my phone was already rocking easily going 1.5-2 days.
do you use any of the following apps regularly?
- whats app
- facebook for android
- weather widgets?
just checking because for the life of me, i can't get more than 23 - 24 hrs usage with ~3hrs screen time. However, I do use these 3 apps pretty regularly
I use whats app, facebook, and yahoo weather. i have noticed with yahoo weather, love the graphics but the more locations you have the more it runs in the background loading data for each city. really uses a lot of data... and i never used the weather widget which i imagine would use some power. at rewipe i havent put it back on yet and just use the weather widget that comes preloaded after a wipe.
- whats app
- weather widgets?
Facebook is a known wakelock monster. I would try deleting the app and just browse facebook using your browser. See if it improves.
For me the problem lay with Google search - more precisely the option to keep listening for hot words. Even disabled this actually still seems to be on. I disabled Google search and battery has returned to normal
