LG G2 - Problems with switch from wifi to mobile data
acehjo
Anyone else have this problem :
when leaving my home (and wifi network) the phone doesn't automatically switch to mobile data service. The only way i can get it to work is to go to tethering/networks/mobile networks and switch the "UMTS/LTE automatic" mode off and back on.
Any solutions, suggestions ?
thx
Same issue here.. any solutions?
thx
Have the same problem. Im using car home ultra to turn wifi off when my phone auto connects to car bluetooth. Not the perfect solution but works for me
I'm not having this issue with the Verizon version. When I'm out of range for the wireless network it automatically switches to data/mobile mode and returns to wifi when back in range.
thx
- - - Updated - - -
Same here
I got that same problem solved after the latest update for my international G2. I used to turn on and then off the airplane mode when that happened. I know, nothing fancy, but it worked. Again, an update should fix it for you.
Sent from my LG-D802 using Tapatalk
Noob
