LG G2 wont turn on but when put into charge orange Led light keeps Flashing only?
  • Start date Start date
A
AC Question
Hey Guys i really need your help asap
i Have an LG G2 .. Yesterday it fell down a bit hard ..and its turned off .. i tried to turn it on but no Luck i put it into charge but the LG Logo keept poping up i pressed the on button ..then the screen turned black and the orange Led Light keept going on and off i left it overnight to charge but with no luck it wont turn on or the orange led will stop going on and off..tried hard resting it but no response ... Do you guys know any possible solution?
Hi, best bet would be to take it to a repair shop - not much else we could suggest. you could open the phone up and look into replacing the internal hardware, however you don't know what is affected and what isn't.
958ryan
