LG G3: Bluetooth Pairing Issue
fsfty
288
My phone is flawless except for one issue. It won't automatically connect to my truck via bluetooth. I have to manually pair the device everytime I want to use it. I don't see any settings on my phone regarding auto connect. Any suggestions? My truck is a 2012 Toyota Tacoma, and my iphone worked fine with it's bluetooth. Thanks.
Re: Bluetooth Issues
Start over by deleting the Taco from your phone and the phone from the Taco. Then pair again but make sure you check the" yes" the boxes when they pop up. Hope that helps.
Thanks...I'll delete the G3 and the Iphone that is still a registered device from the car and see if that works.
Well, I deleted my old Iphone and my LG G3, then re-paired the G3 and its seems to have cured my issue. Thank you very much for your help.
Avatar
