lg g4 camera and battery plus signal
Scumperjumper
159
I have a lg g4. Just got it. I have a few issues.
So the front facing camera isn't to great it's quite blurry when you zoom a little after you take a picture. Same with the 16 mp camera in the back of the phone.
The battery doesn't last long I barely get it through a day.
I have the h815 the international one and I'm in the U.S. but I don't get the LTE sign ever on the top where it showed signals. So does that mean I don't have LTE?
Please help I'm a newbie to android
About the blurry_ness of the image you should recheck the beauty slider to the least.
For back camera check out if u are using the manual mode and settings might be messed up try taking a picture in simple mod and recheck if u peeled off any pasted protected sheet over it.
Ok it's on att but it's a international version. For pictures
The 16 mp camera pictures are the camo lanyard and chapstick.
The 8mp is the keyboard
My friends galaxy s5 2 mp camera takes good pictures why not this phone.... Any help on the LTE stuff?
Thanks for the try, but we need to see the full-size, unedited versions.
You probably need to put the 16mp pictures on Dropbox or something similar.
imgur might work as long as it does not remove the EXIF data or shrink the image.
GoogleDrive.com, OneDrive.com are also options.
Can you check on imgur? I don't want to use Google drive because it might give my name away
Go to settings>mobile data>settings>mobile networks>network mode and look for GSM/WCDMA/LTE
Like this is shows LTE but on top it's says 4g and other phones get LTE here.
This is also my settings. What's apn?
As for my camera will imgur work for keeping it the right size and stuff
Sorry I'm not the tech savvy
