Lg G4 Playstore problem
Hardbullets
3
So everyday I have the same problem with the playstore app. I get the white screen which means it can't load or update my apps. So I clear stuff from Playstore storage and Playstore services and Gmail, reboot my phone twice call the weather network (just because if I don't use the phone it doesn't work) then my Playstore works again. I have gone through uninstalling Playstore and reinstalling, it works for a little while then back to the problem again. My real question here is what is causing this to happen in the first place? Sure I can get it to work again as mentioned above but that's a real pain and I don't think I should have to go through that everyday and I'm not the only one with this issue. Just want Playstore to work as it is suppose to.
Sorry for the delay, didn't have the app but have it now. Booted to safe mode and Playstore worked. Then rebooted and Playstore worked. So I think I know where this is going which I did suspect to begin with, an app maybe causing my problem. Is there a way to troubleshoot which one without having to uninstal and reinstal stuff if that's the case? Maybe some forum that deals with compatibility issues where people have had the same type of problem with apps.
I wish a forum like that existed! Unfortunately, unless there's some known issue that has been reported somewhere, or unless you have some kind of suspicion (e.g., it started soon after installing a certain app), then all you can do is uninstall apps one by one. If you only recently noticed the problem, it would make sense to uninstall your most recently installed apps first.
Unfortunately its been going on for some time and I don't know which app it would be, and I have many. Thanks for your input and now I have a new project to figure out
Thanks
davidlmcshane
