LG k7 WONT TURN ON , PLEASE HELP!!!
  • Start date Start date
A
AC Question
So I've been trying for 2 weeks to get it to turn on , whenever I try it wouldn't turn on or usually stay at 0 but it is very difficult for it to turn after the 1 week
Diagnosis via a forum is difficult. A bad battery or battery connection? A bad power switch? There may be several possible explanations.
I also have had the same problem of this phone not turning on and no display despite charging it. Here is what I found on Google and it worked. Hope this is helpful!
Hold the power button and the DOWN volume button at the same time. It should show the battery needing to be charged.
You can repeat this each time you wish to view the screen until the battery is charged enough to turn on ( if this happens to be what the problem is with your phone)
Also Google search " LG S330 won't turn on". The specific directions I explained will be under the search bar.. Can't miss it!
No members online now.
MercedeZ
