LG g2 Verizon... I want to get a sound/viberate when i get a new text, but i do not want a notification every other second when i get emails and updates.
Welcome to Android Central! You should be able to modify the notification settings within each app. Open your messaging app, tap Menu, then look at the settings for Notifications. You should be able to select a specific notification tone, and turn vibration on or off. Do the same with other apps that give you notifications.
