• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
LG l34C (Fuel) - usb connection problem
A
AC Question
I downloaded the usb drivers and windows media player 10 then attempted to connect the device to the pc. It recognizes it when I have it as a PTP (that is windows explorer shows two folders), but when I switch it to MTP, there is nothing. I am using a pc that is running Windows 5.1 (ancient stuff), could that be why?
Chris Guittard
Just a little more info, I do see where it says that it will only work with XP or later, but am not sure if that is just for synching with media player or to access SD card. I have hooked it up in the past just by downloading the files.
