LG Leon LTE Invalid Battery and Front Camera Not Working Help?
Qwn
1. Invalid Battery Shutdown. Phone keeps shutting off after displaying this message. I tried doing a hard reset, it didn't fix the problem. Bought a new battery, and THAT didn't fix the problem either. Cleared the cache data, but it still has the same problem. The battery is fully charged and will stay on for about a minute or two before shutdown occurs. Also, when the phone is on, the battery does appear to take a charge and it doesn't seem to be draining at an unusually fast rate.
2. The front facing camera used to work fine. Now I can't access it.
Nothing happend for it to cause this, it just happend randomly.
Welcome to Android Central! I would suspect either corrupt firmware or faulty hardware. Is it still under warranty? If so, contact LG.
My phone would not connect to my camera at all. And it would take hours to boot up after being turned off. I started my phone in SAFE mode. The phone does everything but access 3rd party apps in SAFE mode. I tried my camera and it worked. So I deleted all the 3rd party apps to see if that was the problem. I turned it off and started it in regular mode and now my phone is like new again.
Ashok Dharshan
