Lg optimus s zvh root problems newbie, help!!
Jan 24, 2012
9
so I rooted my optimus using the auto root found here, and am currently running hydro's your'mom rom and gingerkernel.
I'm having issues with the sd card constantly un mounting itself, and now the icons on my status bar have disappeared (3g, signal etc) and my phone won't vibrate anymore either. Help!
I would clear all data and caches and reflash the ROM. If you restored any apps with titanium or anything that is a no no. Some of those are known ZVH issues as well.
also, that sounds like a question you should ask in the YourMomROM thread.
Your problems really have nothing to do with root so I agree with Va1ha11a's post.
Vibrate: Go to sound, turn Vibrate to always, then go to messaging app, click menu, go down to notification setting and put Vibrate on always. :D
Go to your mom rom thread and or reflash rom after wiping EVERYTHING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
scoobyd031883
