Lg v20 invalid battery shutdown
Mpgz01
10
Hi I have an issue with the phone, when I had opened the phone the connector is bent. So far only the OEM battery works and any third party battery won't work. Does anyone have solution to fix the invalid battery??
I cannot tell which connector is bent from your photo.
Which batteries are not working?
With the bent pin, there may not be a way to force the third party battery to work. In fact, the damaged pin might not work with the OEM battery at any time. I would honestly look at either fixing or replacing the device. That could cause a short, and damage the rest of the device.
I believe the extended batteries i got are already worn out,even though it is less than a year old.
That wouldn't surprise me, since the V20 has been discontinued for at least two years at this point.
lalarat
