LG Volt 2 stock system dump
rcunningham
222
So I just recently rooted my LG Volt 2 with KingRoot, and I decided it would be a good idea to make a system dump of it. The dump is from a LG LS751 running Android 5.1.1. with build number LS751V4. The phone I got from best buy and for some reason is has no boost mobile branding so you wont find any boost apps, but the boot animation can be found in there. Kinda strange. I really hope this helps those in need.
Download: LG-LS751-5.1.1-Dump
And please make sure you know what you are replacing and what version you are on so you don't create a brick and need to buy a new phone. I posted this in the LG Magna section because the Volt 2 is a variant of the LG G4c and the LG G4c is a variant of the LG Magna.
Hello please how can I install this file on my volt 2 with note it's show "authentication fail #9" and turn off so how can I use this dump.
simply effective
