Light flow vs light manager?
cowbells
14
Which one are you usijg on this phone? I've always used light flow but and thinking that light manager might be a little bit better on this phone... Seems as if light flow is really draining the battery. What do you guys think? What are you using?
Sent from my SCH-I545 using Android Central Forums
I use light flow.. It works great except for the fact it makes my phone speak to me. I understand this is a limitation/bug on Samsung side but I don't know if Light Manager triggers the same behavior.
Sent from my SCH-I545 using Tapatalk 2
I use Light Flow as well. You can fix the bug in Light Flow that causes the phone to speak to you be going to "Settings--->My Device--->accessibility--->text to speech (change to Google), and turn light flow off, under "services". Light Flow will continue to work with these settings, but the phone will stop speaking to you.
andiox
