Light leak
johnnyshinta
2,666
22
Anyone see a light leak at the very bottom edge of the screen. Under the capacitive buttons.
Sent from my DROID BIONIC using Tapatalk
mjforte
670
69
I had a light leak by the capacitive buttons on my Thunderbolt that annoyed me and was pretty common with the Thunderbolt and some other HTC devices but have seen no light leaks on the Bionic.
johnnyshinta
2,666
22
Don't think its enough to get an exchange. My vzw store wont exchange unless its dead basically. They come up with excuses and reasons why the problem is your fault
nickmiller71
233
3
Ive got the light leak like you dude...its annoying but not enough for an exchange like you said yourself
trailblazen
789
84
The droid 3 does the same thing. My wifes D3 does it and my Bionic does it but it doesn't bother me. Just happy to be rid of that stupid storm 2. I also haven't had any of the issues some people are having so Im guessing I got a good one (gotta remember the first batches of phones don't always come to us bug free).
johnnyshinta
2,666
22
I feel ya. Just afraid of getting dust under the screen.
johnnyshinta
2,666
22
Naw, should be just fine. Not to mention I case and screen protect so even if there was a gap I have some form of defense but I don't see it a problem.
I hate cases. Going au naturale. But hopefully you're right and its just an annoyance
ERIC8585
talk
Yes I have light coming out at the bottom of the screen below the buttons in the gap between the glass and plastic. I can only see it in a dark room.
1812dave
3,133
35
Two bionics in the house--neither has light leaks. Nor are the cameras slow to focus in dim light... :) Nor is the screen "horrible" due to the Pentile display, which we like for the great readability in bright sunlight. I could go on...
Arelunde
TECHFAN
Jul 25, 2010
1,308
63
Are you sure it's a light leak? On my Bionic, it looks more like a dock - lighter gray on the lower edge fading to black at the top part, behind the four stationary icons. Note there are shadows under those icons, part of the overall design.
bubbad3
Active member
May 26, 2011
39
I had this very issue with mine when I bought it. My wife's Bionic was perfect so I knew mine had an issue. Took mine back the next day and exchanged it with no problem.
916ninja
397
28
Mine does but I like it that way honestly. It is under each of the buttons and gives it a high class effect. Like it's being projected lmao.
RoyEP3
87
5
Just to let everyone know, I went to Best Buy today to exchange my Bionic because of the said light leaks. I had them open 4 different brand new Bionics and start them up (actually I went to two different stores that each had 2 in stock).
Every single one of them had these light leaks, some more noticeable than the others, and in different areas. But the thing is, you really have to be looking for it to notice it on some of them. And it's harder to notice in a well lit area. It may look perfect at first until you take it into a dark room. I eventually settled for one that had the smallest amount of light leaks. But once again, you wouldn't notice it unless you were really trying to find it. So yes, out of the 5 devices I've seen so far (including the demo unit at Verizon), they all had it.
And here's a repost of a picture of the bionic I returned with what I considered to have one of the more severe cases of light leak.
corymcnutt
615
37
Click to view quoted image
This leak I see on mine (although it's smaller), but since I don't use the phone at that angle, I will never see it and never would have if you hadn't pointed it out...do people really let a little thing llike this bother them? Man, I have more important things to worry about than a slight light leak I will never see while operating my phone in a normal manner.
1812dave
3,133
35
Best Buy must hate you! LOL! Why are u looking at such an extreme angle?
Arelunde
TECHFAN
Jul 25, 2010
1,308
63
The OP mentioned a light leak above the capitative buttons at the bottom of the screen. The photo above shows a light leak at the upper corner of the screen by the notification bar. Different issues?
addrom
