Little Help with G3D 1.2
a22shady
65
3
I noticed in the Tweaks under Display options Both CRT Animatiion Screen Off/On box's are checked is there a reason both box's are checked or should only 1 be checked.
And again I noticed certain options are grayed out unders settings Misc such as "Beats Boost" ,Volume kety camera, SMS screen on etc.. how can I activate Beats Boost.
Is there a way to have the text message's read like they did with original Tbolt or from last update. I dont like the way they read side to side. I prefer one line across
The grayed-out options are for Sense 3.5 ROMs only, G3D is 3.0, so they are not available. I do believe that Beats Audio is automatically rolled into the music player, however. You may only notice a difference with headphones.
Reactions: a22shady
Plug in your headset and play a tune. It will automatically turn on.
Reactions: a22shady
dextriminator
