location based help
bus36daman
Is there any software on the s5 to turn on WiFi or turn off Bluetooth based on your GPS location? My old droid RAZR M had something like this so when I arrived at work my WiFi and Bluetooth would automatically shut off and a text would send automatically. Any ideas how to do this on the s5?
I used to have the pro version of https://forums.androidcentral.com/e...ails?id=AutomateIt.mainPackage&token=HS88yB7x on my S3, I didn't decide to put it on my S5 because I wasn't using it much. It worked well, but I turned off a lot of stuff to save battery life. Amazon has the pro version on sale sometimes, that's when I bought the Pro. I had it programmed to turn off my ringer when it connected to my car and load my MP3 app, then at work it would go into vibrate. When I was within 50 yards of my home it was programmed to turn my ringer volume and all other volumes back up to max. However, it is very customizable for any of your needs.
there is also an app called MacroDroid that has that feature built in... might be a tad more fussy to set up than you are willing to deal with though.
FahadsTech
