Lock screen help
artofdesign
176
9
On my S2 Skyrocket the default music player controls were on lock screen when music is playing. How do I do this on S3?
I don't think you can.
The only way is to disable pin or pattern lock and just scroll down the notification bar from the lockscreen..
I've been able to do that using the WidgetLocker Lockscreen app.
After installation, it lets you add widgets, shortcuts, anything on the lockscreen as well as resize. Haven't found another app that easy to use.
As an example, you have my current lockscreen, using the PowerAmp widget to control music.
koltyn
