Lock Screen: How do I return to a previous setting?
orange-man
53
3
When I first got the One, on the lock screen I could touch one of the four apps and slide up. This would unlock the screen and take me directly to that app. I must have changed a setting because now that no longer works and I don't have to slide anything to unlock, just touch the screen.
What should I change to return to the original function? Thanks in advance.
Sent from my HTC One using Tapatalk 2
That seems strange, the only setting for the original lockscreen is too change the wallpaper, Try changing the lock screen and then change again to the original??
Check your accessibility options. If any of those are activated, it will change the behavior of the lock screen as you describe. Not sure if this is a bug or a feature.
Go to settings, personalize, lock screen style. As you scroll the screens one says " no lock screen". You may have chosen that one.
Asad
