Lollipop Issues!! Help
Hvacmanjc
186
6
Received the update yesterday and have had a lot of issues. Very sluggish, poor screen response and now....apps will not download or update. Progress bar goes roughly 3/4 of the way and then just stops. Has anyone else noticed these issues? Thanks
I had to do it on my Nexus 7 with the lollipop update, and it is not uncommon however much it sucks, but...
You may want to do a factory reset with the update and do a do-over. Not all upgrades happen smoothly, and the performance problem in particular you note is something I have seen before with system upgrades across versions. Usually point upgrades (4.1-4.2 for example) work pretty reliably. But major releases, like 4 to 5 like you just had done, do not always work right. I am running lollipop fresh on my m8 and its running great, so I doubt it is the software itself, but likely the upgrade process. A reset+do-over will probably get you running, though with the work required to do so of course.
I would wipe the cache in recovery first to see if that fixes it. If not, a factory reset is probably necessary
Not seeing any such problems after my update.
Just to check the obvious, have you rebooted?
try rebooting, clearing cache, clearing app cache on the play store app, etc.
Factory reset may not be a bad idea.
Annuji202
