Looking for battery saving suggestions for a rooted phone
Allen Brandt
113
I rooted my G4 (H811 version), using the stock ROM but gained superuser access. I'm looking for suggestions to maximize the battery life.
I'm not willing to shut off WiFi or Bluetooth, and have the location set for battery savings most of the time. My phone is set for WiFi calling as the preferred method.
I'm running Greenify (without Xposed), so it's automatically hibernating some apps (would love to hear what others are hibernating), and I've debloated about 40 apps including the TMobile My Account, TV, ID, etc. I also installed AppOps Pro and shut off Keep Awake for most apps, along with location sharing (and the usual app abuse of my contacts and calendar, etc)
Anyone doing any other things to save power? Thanks in advance
Titanium backup can freeze apps that the stock rom can't...
Posted via the Android Central App on the LG G4
(or the Samsung Galaxy Tab S 10.5...merica)
Is Titanium backup better or different than using the debloater tool to freeze apps?
Im new to the G4, but if I recall in a post on XDA someone had said that Ti is good because it can remove any app you want whereas debloater tool can only freeze most of them. That being said, Ti can be a bit dangerous if you remove things you shouldn't, so most recommend just freezing them until the boot loader gets unlocked and custom debloated rom's start appearing.
This
But hence the name, you can create a backup to your SD card and then debloat away as well. TiBu really is much more than a debloater or disabler.
Turn down your screen brightness manually. Stop background sync of apps that don't need it. Everything else is icing on the cake.
paulmloucks
