Loud continuing bursts of static noise when using bluetooth headphones
  • Start date Start date
A
Android Central Question
The last couple of days my Sony Wh-1000xm2 have started to behave erratically. What happens is this:
I listen to music, and suddenly the volume is bumped to max and loud, rhythmic bursts of static-like noises starts blasting kbto my ears. For some reason it's only happened in the evening, and it stops if I plug in an audio cable to the device (I don't have to connect the other end to the headphones). Does anyone know what the problem might be, and have a solution to it?
akiremylionel21
