- Sep 19, 2012
- 208
- 0
- 0
I've started noticing that the Samsung chargers aren't running anywhere near the rated output they are suppose to be running. I noticed this with both mine that came with my GN2 and the one that came with my wife's GS4. I'm using the Galaxy Charging Current app and I see most of the time, when I plug it in, it reads around 300-400mA. Even plugging it in, using the white cable or any other USB cable into a computer USB port, I get 400+mA. I have a cheap automotive 2.1A unit that always pushed at least 900mA when I have my phone plugged into it.
Last night, I plugged in my phone with a starting charge of about 8-10% remaining. This was at 11pmish. By 4am, I had only reached 33% and the GCC app was still showing that I was only getting about 300mA's. When I first plugged it in, the reading was around 400mA's. I had everything turned on on it(WiFi, Bt, Sync, GPS) except for the phone service itself.
Is it possible that both of the power transformers in the factory plugs have gone bad and are not putting out the required voltages? I have a couple of decent quality DMM's but do not know exactly how or what pins I would need to probe to see what's coming out of it. Is there such a thing as a USB/MicorUSB port that allows meter readings?
Has anyone else had similar problems to this that can document it? I had an issue with it early on but discovered the random charging issue was attributable to the charge card inside the phone not having a proper connection. after I plugged the card back into the main board it's not happened since.
