Low Memory Help
bling300c
18
How do I determine what is eating up my memory. Advance Task Killer reports only 40M of free memory. I have no idea what is taking it all up. Any programs that will report? I just did a factory restore but Google reloaded a bunch of stuff automatically.
Ed
i say delete all apps and install taskiller and review it one by one. it helped me alot with loss of mem. also i notice closing open apps will help too everytime you are done with one app.
40MB of RAM free is 100% normal and even quite good. If you are indeed talking about RAM than you're fine. Most droids will actually have under 10MB of RAM free at any time and lots more RAM used up by a memory cache. However, when the free ram gets low, it garbage collects from the ram cache and thus that becomes available. In looking at a task killer, the free RAM displayed is the sum of the actual free memory PLUS the memory tied up in cache which is considred free, since it can be killed at any time.
On my device, i almost always hover around 30MB total free when looking at Advanced task killer. Any my performance is excellent. Closing apps via a task killer is really not necessary. The OS handles this on it's own.
If you are talking about the actual ROM memory, then you would have to look into your apps installed.
uninstall your task killer/manager program and your phone will run better.. search any forum and you will see the same advise.. linux does an amazing job managing tasks and memory.
I have Astro...where/how do you determine ROM memory?
My 40MB is RAM and I agree - 40MB is normal.
Thanks,
Ed
+1 on the 40MB. I tend to be hovering around 40 every time I check, and have yet to see any performance issues because of it. I have to agree, 40 is probably pretty normal.
drhathu
