Low speaker volume
johnnyshinta
2,666
22
I have the volume maxed and I still can't here the notifications. Anyone having this problem?
Sent from my Incredible 2 using Tapatalk
i'd agree...it's not that loud. remember, the speaker is on the back so if you have your phone on the couch etc. it will get muffeled when notifications come through.
I did a few test calls on the Inc 2 and used the speaker phone option. Terribly low volume, even at the highest setting.
I am not noticing that issue
Me neither. I have my master volume half way and can hear the notifications just fine.
OP, you went into settings, volume, and then made sure the notification volume was up (not talking about master volume)?
I've had to turn down my notifications because it's too loud and the speaker phone is loud and clear..
yes i've made sure the volume is up. i changed the message tone to default and that seems to have fixed this. i was using the same notification i had on my DINC1 and its softer on the DINC2.
weird
I have a brand new droid charge....3 days old and the volume is almost non-existant! I just may be returning this phone. BIG disappointment! Any suggestions. I use my phone for business and this doesn't work for me. Any help?
Thanks
I had the same with the Dinc2 and returned it. I am on my Droid1 until the Bionic releases. But, I'll never but a handset again with out trying them at a store.
Volume is a big deal maker/breaker with me.
Heartworms
