- Aug 13, 2016
- 4
- 0
- 0
I think if you've gotten close enough to it to spin before, then go to that range you are in right now it should still work. I've done it plenty of times. Never had to stay close enough to spin it, but would still get the pokemon
If it's spinning like that, you should be in a pretty good range.![]()
No it doesn't guarantee a rare or uncommon pokemon at all. Just seems to attract one every few minutes. I seldom get anything that's not common around lure modules. I've heard if you get between 2 close together (meaning you can collect from both at the same time) pokestops and throw a lure on them both and use an incense you have a higher probability of rares but I haven't tested that yet myself.Actually it's not spinning. But I do get some pokemons whenever they use a lure module. About 4-5 pokemon. Does that indicate that it affects my current location? and the pokemon I usually see are oddish, doduo, horsea etc.
What's your experience with lure modules? does it guarantee a rare pokemon or something or any unusual pokemon?
TYIA
Thanks for the comment man. Appreciate it!![]()
TYIA
