Major battery drain
Verdes8891
1,845
154
I haven't even used my phone at all today except for a couple of text messages and a little Facebook. Maybe a total of 10 min worth of usage. Other then that it has been sitting in my pocket. I am rooted on the rasbean ROM with Francos kernel installed. Any suggestions would be helpful.
No idea. That's strange.
Maybe your screen isn't turning itself off?
Sent from my totally awesome Sprint Galaxy Nexus, even if I don't know all its secrets yet.
Could even be the ROM your running has some memory leak issues which is causing the battery drain
Your phone app is showing massive usage that tells me you probably have a wakelock. I would Google better battery stats xda and grab the app to monitor your phone and see if you can find the abnormality.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Also give me a screenshot of the the other battery graph. The one that comes up by taping on that graph.
Thanks for the suggestions guys. The ROM I am using updated the other day and everything seems back to normal now. I also got rid of Francos kernel. Seems to be good now.
That's good cause my next suggestion was going to be to check your phone logs to be sure you weren't butt-dialing someone.
Funny thing is I did check them. Nothing. I didn't even open the phone app that day. It confused the hell out of me.
marksains61
