maps draining my battery
Octaviannn
129
Can anyone say me what to do if maps are draining my battery? Its using 40% of the battery. I usually "force stop" the app. Any other ideas?
P.s. gps is off, but google locations is ALWAYS on. Maps are draining my battery only after using navigationsystem.
Posted from my Nexus 4
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,713
4,872
113
I wonder if Nav is staying awake and using battery even after you're done using it. I never use Nav, so I can't be sure.
One thing you could try is to turn off Location Reporting, which lets other people know where you are (used for the old Latitudes app, now incorporated into Google+). Location Reporting tends to increase the number of wake locks executed by the phone (in order to access the web and report your location), which can use up battery. Turning off Location Reporting won't affect the ability of apps to access your location. Go to Maps/Settings/Google location settings, tap Location Reporting, and turn it off, then see what happens.
You can also install an app like Wake Lock Detector to see what specifically is using up most battery power.
Octaviannn
129
Well, i would like to keep location reporting on. It does suck some juice, but not so much, and not maps.
Octaviannn
129
I turned gos off, then i restarted. Inly after this it went really off. I dint want to restart my phone always. :/ is there another way to fix it? Hmm i think this is a 4.3 bug.
anon(847090)
6,655
31
I hope you are using the latest maps!!! Maps 7.0 saves a lot of battery.
if nothing help, clear data/cache for maps and set it up again
sams_s22plus
