Maps keeping device awake - killing battery
ITensEI
3
For whatever reason my S4 keeps dying on me randomly. I've discovered that Maps is using like 40-60% of my battery and keeps the device awake even though I haven't opened maps or used it at all. I have since blocked the Keep Awake permission for Maps with App Ops, but the problem didn't go away. What could be causing this? I have maps on a S5 and that has no problems.
Some pictures:
Hi there ITenseI
Going to pass this on to some really smart folks. See if we can get you sorted out!
Chris
Have you tried clearing the cache for Maps?
Settings> Device> Applications> Application Manager> Scroll over to "all"> Scroll down to "Maps" Clear Data and Cache.
You can also try disabling/reinabling Maps in application manager as well. Uninstall updates is another option.
Compliments of one of our other Ambassadors: Tourbound129, if this works!!
See if that helps!
Chris
Thanks Chris,
I have tried clearing the cache and data. First thing I did. I'm a bit reluctant to disable it completely, but if there's no other solution I will have to do that. I figured simply blocking the keep awake permission using App Ops should be enough, but it didn't work for some reason.
Jolyon39
