Maximum capacity for MicroSD cards?
isamu99
9
Hi. What is the maximum storage capacity on MicroSD cards that the shield will read? 32GB or 64GB? 128GB? I'm thinking of holding out for a 128gb Sandisk.
64gb is the largest I've seen them come in, but I'm sure the 128gb ones are around the corner.
Sent from my Nexus 7 using AC Forums mobile app
Welcome to the forums!
SDHC SD cards are limited to 32 GB. SDXC SD cards have a theoretical limit of 2 TB, however, the largest I have seen is 64. I think 128 GB is current maximum for Sd cards, not micro.
SHIELD will support 64gb cards. Any higher and I can't say for sure.
The Verge said that any microSD over 32GB requires being formatted NTFS via a PC. Is this true? Does this mean that the 32GB or smaller are just normal FAT32?
I don't have a smaller capacity here to test with, unfortunately.
I'm pretty sure that it's a limitation of the file system though, so what you said would be true. Don't quote me on that, though. I have no way to test.
Sent from my Nexus 7 using Tapatalk 4
So it's possible to move apps to the SD card? Before I go buy a card I wanted to find out.
Well turns out with the new update you can move some apps and some data. I was able to move Asphalt 8 and Madden almost completely to SD card. The app of Bard's Tale, but not most of the data. Freed up a lot of space. This is with a 32 GB class 10 card.
