[MEGATHREAD] WE2012/Winning Eleven problems
Tongasious
App installation
Hello
First I downloaded Winning Eleven Game Apk on my Techno H6 and I really enjoys it..
But unfortunately I restarted my phone and I downloaded the Apk again but wen am installing it says "App not installed".. Any help pls?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
163,621
2,272
113
Re: Why am I getting an error message when I try to download an app?
Welcome to Android Central! Are you able to install the game from Google Play Store or some other legitimate app store? It's generally inadvisable to download and install apk files from the internet, since the sites where you find them are not regulated, and therefore puts you at higher risk for malware. Those sites often promote piracy as well.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
163,621
2,272
113
Re: Why my we12 game is not opening
Welcome to Android Central! Also, did you install this from the Play Store, or from some other source? If the latter, the game might not be compatible with your device (or worse, it might be malicious).
A
Android Central Question
After installing konami we 2012 the game was not started on samsung Galaxy j2
What is the problem and solution regarding to the problem
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
163,621
2,272
113
Welcome to Android Central! Did you install it from the Play Store or from some other source? If it wasn't the Play Store, there's more chance that it's not compatible with your phone.
A
Why is the app we2012 failing to run on my itel a14?
I once installed we2012 and it was running smoothly but ever since I unstalled it ,it as been just bring black on my screen nothing is showing not even where by it says"app not responding".At first I thought that I was because I updated the phone but I tried formatting it and still it's not working.I have tried several times but nothing is working ,the is successfuly installed but when I enter in the app my screen is just blank I don't know why.
Rukbat
Retired Moderator
Feb 12, 2012
44,533
20
Re: Why is the app we2012 failing to run on my itel a14?
WE212 is a 7 year old app, designed to run on JellyBean (API 16-18) - it probably won't run on a modern version of Android running API 26 or higher.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
163,621
2,272
113
Winning Eleven 2012 is not available on the Play Store, and it would not be advisable to try installing it as an apk from a random website (since that's a good way to get malware). The current version of that game is eFootball PES 2020, so try installing that instead.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,194
94
48
Re: Why my phone doesn't play winning eleven 2012 & solution
Perhaps whatever phone it is doesn't have the right specs. With no info, we can only guess.
Mooncatt
Ambassador
Feb 23, 2011
10,559
118
63
Re: Why can't my camon 11 phone play winning eleven game
From what I can find, this is a limited regional released game for some Asian markets. If you aren't in those markets or didn't install the game from one of the official sources, then all bets are off.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
163,621
2,272
113
Welcome to Android Central! Where did you install it from? The Play Store, or somewhere else?
