Messaging issues with Galaxy Note 3
quay69
46
Is anyone having any issues with their text messaging freezing up while typing, my note has been acting up for the past two weeks every now and then in mid text message it will freeze up for 20 seconds and if I keep typing it will force close
Sent from my SM-N900T using AC Forums mobile app
I had the same issue I just did a factory reset it helped out a little bit.... But I fully got rid of the issue when I switch my messaging app to hangouts way better then stock message app... And I also switch keyboards to SwiftKey... And what a difference amazing.... Types as quick as an iPhone
This sms lag turned out to be a keyboard issue for me. I switched to Swiftkey and the problem was solved.
