altruisticbees
Active member
Aug 16, 2012
39
Nope, that doesn't look compatible. It says It supports the s2, but the MHL cables for the s2 and s3 are different. Normal MHL cables are 5 pin, but the MHL cables for the s3 up are 11 pin and require power. I'd suggest just getting the official samsung accessory, or if you buy a third party cable make sure they say it specifically works with the S4.
Google_Superuser
321
Ok thanks. Frys doesn't have the most up to date website so I wasn't sure if they just weren't listing the S4 due to being out of date or because it was different than the S4 cable.
Pode43
