mic sd card help
If you're speaking about getting them from a computer to the SD card on your Note 2 there are a couple of ways to do.
If you have a Windows PC you can connect via USB cable and transfer through Windows Explorer.
or
You can install Samsung Kies and transfer wireless.
Sent from my SAMSUNG Galaxy Note 2
If you want pictured you take and store in your phone to go to sd card just open the phones settings and select ex sd storage
Note 2,,ITS TRUE, SIZE IS EVERYTHING.
aldwuina
