Micro SD for Edge+? No problem!
browetally
108
So I ordered a Micro USB SD card reader for my Edge+. It works great! It is from Meenova. I also bought a 64GB SD card. While I can't figure out how to change storage locations for the default camera app, I was able to set it up properly with Camera Zoom FX so pictures taken will save to the SD card if it is present. If not it saves to the phone.
Sent from my SAMSUNG-SM-G928A using Tapatalk
Good thinking! Is that card reader bulky? Do you have to connect using an OTG cable?
No OTG cable. Just plugs right in. The card reader is not bulky at all. I've attached a picture. uploadfromtaptalk1441761567719.jpg
That's a good solution. I'll have to keep this in mind when other users bemoan the lack of an SD slot!
As someone who dearly misses the SD card slot, I bought the same thing and put my 128GB card in there and put it on my keychain. If I ever need my files, it's just a plug away.
One step ahead of you man
