Minimal Shutter Speed Setting
Younjulius
69
It doesn't look like users can set the minimal shutter speed with the camera. It's pretty annoying that the camera constantly set itself to 1/17 shutter speed as if it's an acceptable speed. I'd rather move ISO up, or at least limit the minimal shutter speed above 1/40.
Anyone has any experience dealing with this issue? I just learned about anti-shake feature. I guess, I'll try to experiment with it.
There is an ISO setting up to 400 I believe it said. Mine is set to auto
If you enable "Anti-Shake" in camera setting it will set min shutter speed to 1/33. This is all Anti-Shake does in still mode, I always have it on. In video mode it uses active software stabilization, which is why the image is cropped with it enabled. Luckily, the Anti-Shake setting is independent for stills and video.
rose1988
